you by the sounds of it.........
what is everyone up to today anyways?
im doing more research on parts prices for the R34 at the moment............
im regretting saying i could work tonight cause now i cant pick my engine up :blush:
epic fail
looking up stuff that im gonna need for my build for the supercharging project.
i dont need to worry about the engine side of things cause i have Chris Milton Engineering Developments sorting that side out for me, its just everything else i need to sort out.
Good turnout at Enfield RSL's dawn service in spite of the rain and it being a Sat... couple hundred there easily :blush:
-D
Was a good turnout at brighton dawn service
as was there in town at the march
and need i say, it BELTED down with rain (just as our unit was about to turn from north terrace onto king william road.......and it rained all the way through to the end just by the memorial hospital
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
