yay golf talk lol
i have been playing a fair amount of golf pretty much every weekend.....getting my scores down which is good...best so far has been 32 on 9 holes par 3....anyone keen for a SAU golf day....groups of 4
Edited by Krishy
I normally go around on my own in about 1.5 hours. But depends how good golf we play. OK, let's say 3:30pm at my place, that way we can have a roadie, and be on the course just before 4pm. If it gets to 5:40pm we can give up and head back to my place.
So, SLED is in, Madaz is in. Any other takers?
Fark! I have the day off, but im heading to victor at 12 for end of season cricket trip.
Krishy, organise a golf day!
Par 3 isn't the best of fun though..... Need to go out on a real course where you can at least take the big dog out and try nail one down the middle...... :P
North Adelaide is good for that
Yeah it's not too bad.... there's the Patawalonga as well near the airport as well or for a nice easy 9 hole course there's Regency. Sandy Creek and Mt Barker are a couple of my favs though.....
yay golf talk lol
KEEEEN AS BREW!!!
I make a point to NEVER pull between stationary cars to turn - even if they leave you a gap to do so - it is just too risky if you can't see who you are pulling out in front of. Just because you can't see them, doesn't mean a cyclist or motorcyclist isn't there.
I made that mistake on the side street between kfc and hungry jacks at reynella....everyone had stopped and left a gap..so i went through...some F@&$wit in a camry comes flying up in the turning lane and scared crap out of me so i booted it...luckily i was still n/a , only problem i was open wheel so i just wheelspan....4 cars back was a cop car which rapidly did a u turn and pulled me over to do me for excessive noise....they didnt care that the camry nearly hit me and i took evasive action..imo, they just saw a skyline with stockies
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
