yay golf talk lol
i have been playing a fair amount of golf pretty much every weekend.....getting my scores down which is good...best so far has been 32 on 9 holes par 3....anyone keen for a SAU golf day....groups of 4
Edited by Krishy
I normally go around on my own in about 1.5 hours. But depends how good golf we play. OK, let's say 3:30pm at my place, that way we can have a roadie, and be on the course just before 4pm. If it gets to 5:40pm we can give up and head back to my place.
So, SLED is in, Madaz is in. Any other takers?
Fark! I have the day off, but im heading to victor at 12 for end of season cricket trip.
Krishy, organise a golf day!
Par 3 isn't the best of fun though..... Need to go out on a real course where you can at least take the big dog out and try nail one down the middle...... :P
North Adelaide is good for that
Yeah it's not too bad.... there's the Patawalonga as well near the airport as well or for a nice easy 9 hole course there's Regency. Sandy Creek and Mt Barker are a couple of my favs though.....
yay golf talk lol
KEEEEN AS BREW!!!
I make a point to NEVER pull between stationary cars to turn - even if they leave you a gap to do so - it is just too risky if you can't see who you are pulling out in front of. Just because you can't see them, doesn't mean a cyclist or motorcyclist isn't there.
I made that mistake on the side street between kfc and hungry jacks at reynella....everyone had stopped and left a gap..so i went through...some F@&$wit in a camry comes flying up in the turning lane and scared crap out of me so i booted it...luckily i was still n/a , only problem i was open wheel so i just wheelspan....4 cars back was a cop car which rapidly did a u turn and pulled me over to do me for excessive noise....they didnt care that the camry nearly hit me and i took evasive action..imo, they just saw a skyline with stockies
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
