can someone link me or give me the jist of how a permit works? im lookin into a track car without the need (preferably of a trailer)
say i have a car that is not registered, not defected but i want to get to a hill climb/track day etc etc is it hard?? or only hard for those on defect?
then how does this effect your insurance as the car is not registered?
PM sent.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
