math not ya good subject? :P thought watching for card counters you would have some skillz
real cars come with boost gauges :P and only milk n juice come in 2LT etc etc
actually, im not bad with maths. occupational hazard.
haha, you can keep your crappy inaccurate standard boost gauge, and you can cram your extra 600cc's...
Wow ... I just landed an awesome job at work! (sense the sarcasm?)
Create a directory on our intranet and transfer 10 years worth of Development Plan CDs onto it. 12 CDs per year x 10 years = over 100 CDs (some months had no Development Plan editions) @ over 500MB per CD of info = massive headache. Some of the CDs are beyond their shelf life and not reading properly for the transfer. Oh goody!
:P
Found a CD thats hard to read. Damn Marion Council Development Plan in PDF is corrupt. Work colleague just walked past and made the joke: aren't Council's corrupt anyway? :P
does a dented sump cause any damage?
Depends on how bad the dent is, and if its affected/restricted the oil pickup.
... oh, and obviously, that its not leaking!
Edited by RubyRS4
I had a big dent in my sump on the 32 when I had it, I just put in a bit extra oil till it was just above full on the dip stick - the dent made it look fuller then it was.
:P
Reminds me of a time I saw a biker at the BP. Motorcycles are to be topped up with oil in an upright position, not on its side stand. This one guy was convinced the level was to be maintained on its side stand and he had not overfilled it. It was a brand new bike and he said the dealer's mechanic didn't fill it up enough. Of course, his 2 years riding experience bettered my 20 years riding experience and an experienced bike mechanic, so obviously he was right :P
He killed the bike after 1200kms :)
Edited by RubyRS4
its on the CA damo! anyone got a stock CA18det sump laying around (dale) hehe..
and need urgently a Small FMIC like the jjr one.. dont have the time to wait for it to come!
I have a 450x300x70 fmic if thats what you're after?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
