its on the CA damo! anyone got a stock CA18det sump laying around (dale) hehe..
and need urgently a Small FMIC like the jjr one.. dont have the time to wait for it to come!
Contact Smooth Garage and speak to Niko, tell him Kye sent you to him.
They would have HEAPS of CA parts laying around. Niko just finished ripping out his old CA so you might be in luck.
yeah Chris cant answer that one i would depend on the assessor on the day and all sorts of contributing factors
i was making a point that if they deem that mod to of caused the accident its highly likely they will void your insurance
Thats a genuine possibility, but generally if you have your modifications performed by an accredited mechanical workshop (and have reciepts to prove it) then you're fine.
If you've done something like welded a diff or chopped springs etc, then its very possible that they'd use those as an excuse to at least reduce the payment
Best to call the insurer in either case and see what they will and wont insure... and if they do, get it listed. Its worth paying the extra $20-50 per year if it keeps you completely covered.
-D
anyone got a plate for a stock bov wanna have some mad flutter styles yo before I leave adelaide :blush:
all you need is a coke can mate
not hard at all and i think that there is a DIY thread somewhere
goodluck and it seriously takes 5 mins if that
unbolt the bov, cut a coke can and lay it flat, so you have a sheet of metal. then trace the bov on the coke can, and the bolt holes. cut out the holes for the bolts and put the can sheet in between the bov and the flange.....and bolt it all back up nice and tight.....presto u got flutters
haha, mack trucks win!
ill be getting it dyno'd again next week, see how much i pick up with the AM pipes and hi-flow cat. extra 3 or 4 psi should net a healthy handful of killerwasps.
Edited by scandyflick
.....heads out to the garage.....
lol
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
