Playing with the new PC box for my surveillance last night. Took a bit, but got it working. Then I find out its not accepting my password to configure the software. I definitely wrote down the password when I installed the software. Time to reinstall the software and try again! Tonight I'll plug in the cameras and see how it performs. Next I upgrade the cameras and log in over the internet, so I can watch my f**king dog misbehaving from work. :huh:
200's almost there. just gotta put the airbox, inlet, and hotpipe back on. well, that and a couple new dump pipe studs >.<
lost a couple nuts for the airbox, so ill be heading down to coventry's to get those soon, if all goes well, it should be fired up and driving for the first time since ajd this afternoon. awesome.
Saw the latest Rapid mag and saw the turboed Brutale. Madness :rolleyes: The engine has no bottom end revs to begin with ... reckon it'd be too laggy.
I'm selling the Brutale now anyway. Putting the mighty TLR back on the road, and over the next couple of months customising it a bit more :blink:
dude if you EVER want to part with the TLR plz hit me up ey
:P
which one????
nearest one is salisbury.
depending on what size, motor traders have a small range of nuts and bolts....we dont have a minimum....unless its eftpos...then its minimum $10
the ones im after are pretty common me thinks. got small bolt in the same thread i need, just need a larger one, and a couple nuts, id be surprised if they dont have them.
oh yeah, dump pipe. :rolleyes:
tis awesome.
Edited by scandyflick
:P
I have thought about it ... but it almost tore my guts out.
But that day may come one day. I do already have a list of mate's who want it (and would kill me for it :rolleyes:) but I'll keep you in mind, in case I see a new toy I want.
Nugsy, you might recognise the TLR like this when I use to drag race/track day it ... just before I got my drag bike built.
This was before all the good stuff went on :blink:
Edited by RubyRS4
i can send an email down saying ur my cousin and to do you good deals if your goin down that way if you want
yeah keep me in mind in 5yrs time if you part with it.
always wanted a v-twin, and the TLR would suit me nicely
mind you, an rsvr aprilia Mille or honda sp1/sp2 would be interesting as well
meh atm, sciatic nerve rhs is real bad, can barely sit down now after 10days
one year tho I'll get back on the road.
thursday is dynotune day............ yay
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
