lol, family guy:
Chris: Dad, what's the blow-hole for?
Peter: I'll tell you what it's not for, son. And when I do, you'll understand why I can never go back to Sea World.
http://www.familyguyquotes.com/characters/...n-quotes-3.html
give me ur sr20 when you upgrade scandy, could use it in my pulsar for some torque steer fun. if the shell dosnt rip in half first
Rip the back half of the car up, rear mount the SR20 for Pulsar rwd fun.
http://cgi.ebay.com.au/1993-Nissan-Skyline...93%3A1|294%3A50
This guy is kidding right?
It'd be hard to sell. You could get an R34 GTR V-spec for that kind of coin :P
Edited by RubyRS4
yes both, :P
for me? please? :)
What are ya gunna do? ... spank me! :P :P :D
I'll only have the Stagea for the show. Too much to do. Wouldn't have a second entrant in time ... not in a fortnight. ;)
yes spanking could be part of the deal if need be lol :):P
well considering i found out i was lied to about the rear wheel power figures with the 850hp blower, the other two options were to a) go to a 1200hp blower which would cost me $4500 on its on (then on top of that would need belts, etc) or b) go turbo
now as much as i dont want too :P
im seriously considering the T51R as my turbo of choice, it has also been recommended to me by Sam at Chris Milton Engines, ill be going with the 1000hp one, which also means going RB30 bottom end, (dont have a choice).
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :D kinda works out good i think lol
and ;) to you to dave :P
:) I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
:P I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
i was only getting the stuff from them Luke, they werent actually gonna touch the 34 at all. i wouldnt be recommending that business to anyone personally. but hey, at least i found out before i got the stuff, i just cant believe they lied :devil: i think its so rude.
Get yo' bits, T51R SPL, etc etc, get it to Willall, and let them work their magic.
Willal.
no.
sorry.
John Keen will be the only one to ever work magic on my car Damo. you should know that as well.
is the T51R known as anything else tho? cant find it on the Garrett website. so im guessing its been renamed?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
