lol, family guy:
Chris: Dad, what's the blow-hole for?
Peter: I'll tell you what it's not for, son. And when I do, you'll understand why I can never go back to Sea World.
http://www.familyguyquotes.com/characters/...n-quotes-3.html
give me ur sr20 when you upgrade scandy, could use it in my pulsar for some torque steer fun. if the shell dosnt rip in half first
Rip the back half of the car up, rear mount the SR20 for Pulsar rwd fun.
http://cgi.ebay.com.au/1993-Nissan-Skyline...93%3A1|294%3A50
This guy is kidding right?
It'd be hard to sell. You could get an R34 GTR V-spec for that kind of coin :P
Edited by RubyRS4
yes both, :P
for me? please? :)
What are ya gunna do? ... spank me! :P :P :D
I'll only have the Stagea for the show. Too much to do. Wouldn't have a second entrant in time ... not in a fortnight. ;)
yes spanking could be part of the deal if need be lol :):P
well considering i found out i was lied to about the rear wheel power figures with the 850hp blower, the other two options were to a) go to a 1200hp blower which would cost me $4500 on its on (then on top of that would need belts, etc) or b) go turbo
now as much as i dont want too :P
im seriously considering the T51R as my turbo of choice, it has also been recommended to me by Sam at Chris Milton Engines, ill be going with the 1000hp one, which also means going RB30 bottom end, (dont have a choice).
but at least i know ill definetly be able to make my minimum power of 500rwkw :P aqnd if i wanna driver her on the street, i can just put her on low boost :D kinda works out good i think lol
and ;) to you to dave :P
:) I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
:P I would hope you are no longer using the workshop who promised you 850hp out of the supercharger. You were told by MANY professionals on here this simply wasn't possible but you trusted the people behind the work to come through. Clearly they were out to screw you, I wouldn't be going near them for this build
i was only getting the stuff from them Luke, they werent actually gonna touch the 34 at all. i wouldnt be recommending that business to anyone personally. but hey, at least i found out before i got the stuff, i just cant believe they lied :devil: i think its so rude.
Get yo' bits, T51R SPL, etc etc, get it to Willall, and let them work their magic.
Willal.
no.
sorry.
John Keen will be the only one to ever work magic on my car Damo. you should know that as well.
is the T51R known as anything else tho? cant find it on the Garrett website. so im guessing its been renamed?
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
