You'd be silly NOT to go to Willall, they know 30's back to front having built some real monsters but each to their own
Yeah but so does John Keen, and why should i change now after all the work and help that John has done for me for nearly three years? sorry cant do it.
John also built Jake's VL that was pumping out 650rwkw. And that was a RB30
Guest CleanAndSimple
was peaceful untill you rocked up with ur "hoon" car :devil:
My car lives under a car cover for 10 more months :P
*sits in car making broom noises, thinking of hills*
common-whore's don't count, coz it doesn't matter if they blow up LOLZ!!....
that was a stab on common-whore's not John btw,
Edited by CleanAndSimple
My car lives under a car cover for 10 more months :(
lol my girl is under blankeys too atm :( until tomoro when i will awaken her :P
sadly enough most people already know me cause of the skyline here :P scarey shit i tell ya lol
lol i realise that.
unfortuntly jake had a crash in it on the drag strip bout a year and a half ago i think,.
as far as i know he is building another engine lol
sadly enough most people already know me cause of the skyline here :devil: scarey shit i tell ya lol
You could have turned up in a space ship. Would've had the same effect :P
Edited by RubyRS4
should tell him to get another shell :P
yeh well :devil: coz i cant drive mine so mmm *continues to make broom noises in car*
many old people look at you like you just stabbed someone down when you drive past down there?
should tell him to get another shell :(
broom.
broom broom vbroom.
pssccchhh?
:P
um i havent driven the skyline much since ive been up here, havent driven her at all in the last week,
but to be honest i never really noticed, i think people were more curious to know who the car belonged too than anything, she always seems to be a hit when in the Bridge with all the younger kids lol
loll, my car hasn't been started in a week, i feel so guilty lol.
*shakes head*
liking the corolla too much are we?
they probz dont see many real cars up there, all bogadores and falcooon's sitting 10foot up in the air.
dont worry neither has mine.
the corolla is ok. needs some work, needs new leads, possibly starter motor, and all new belts but that is about it.
and nah there is a couple of skylines in the bridge, but dont really see them that often. but yeah there really isnt anything exciting, occasionally see the nice car across the rd from work at the servo, but not often.
lol i thought u said needs new led's. i was like :P what? led's corolla lol....
thinking bayside blue for my car sometime this year or black ameth :P then i come car shows too n show n shines and stuff :devil:
i was thinking of painting the corolla home job matte balck style lol :(
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
