you know whats awesome?
graphics.
... and sarcasm.
yes i know my graphics are awesome thanks dave :cool:
and yes, dan is quite good at sarcasm too
maybe i should get some fully sick dragon graphics for the rolla? :)
the following tests will be carried out,
0-400m sprint, self explanatory really. test will be held at anzac international raceway.
the shopping test, leave both cars parked at tea tree plaza while the owners shop for 2 hours and come back to load their shopping into their cars, points are awarded for the most shit squeezed into the cars, and points are deducted if the car has been vandalised/stolen/laughed at.
the hindley test, a saturday night hindley st lap at 10pm. points will be awarded for the amount of positive looks (smiles, nods, thumbs up, etc) a car receives, and deducted for negative looks (laughs, obscenitys yelled or implied, etc).
the maccas tests, standard maccas drive through with 2 people ordering in each car, points awarded for not scraping wheels, not having to lean out of the car, etc. test will be held at ttp maccas.
the defect test, each car will go through a defect station, points are awarded for getting through unscathed.
the winner will be awarded 1x internet.
Edited by scandyflick
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
