Injectors won't help the turbo make power but cams will.
Also Garrett prices were increased 30% at the end of last year.
My turbo i got 18 months ago for 1000+ GST trade i can't get for less than $1490 now. It'll be interesting to see of HKS have also mover their prices because Garrett will have moved their prices in to HKS range if they haven't
I know Phu talked a lot of smack too :P
But he may have had a massive turbo .... great if you own a dyno queen, but forget mega lag for the street.
I remember MattR's white ex-JMS R32GTR that made over 500rwkw, but with the T51R made very little power until around 4,500rpm - when it would make 100rwkw per 1,000rm and the power hit like a hammer. Was quite insane. Awesome for the drag strip and dynos, bloody horrible for the street.
Hence why Munro has gotten rid of his and downgraded to a pair of 25/40s for his RB30DETT streeter - significantly improved streetability for a relatively small sacrifice in power. Puts a MASSIVE smile on your face too :):P :P
Turbo back exhaust, pod filter, intercooler, 12psi boost, fuel pump and remapped ECU(can get it done through turbo tune[my mate got his done there with the mods I mentioned and got a smidge under 200rwkw on their dyno])
i got 186kw when willal got there mainline dyno and i had 3" turbo back exhaust, fmic, power fc, fuel pump and boost was 13.8 psi so go figure! same as my mechanics r34 gtt he got 191kw!
^^^ The RB25DET NEO is a vastly superior motor to the R33 RBD25ET including enhanced valve timing, cam timimng and various other tweaks. I am surprised your results were so close Son - often there is 10-20% difference between NEO and non-NEO motors with the same mods.
my car was breathing better than his with the decat, straight through exhaust. but it seems right normally there's a difference of 5-20kw between neo and non neo rb25! but the difference was powerband, mine boosts quicker than his but ran out of puff at the higher rev range while his car ate mine at that point, it felt alot more punchy at top end
but i think the extra bit of torque and power comes from more duration and lift from the cams! i'm not sure how vvt works but i think the cams twist? like how v tech kicks in! i could be wrong but that's my guess
ok cool
ill have a look at some garrett turbos tomoro if i get time....see what the deal is with them :)
thanks heaps guys :P
Im running standard turbo at 12psi, making a little over 200rwkw with power fc, fmic, free flowing exhaust, bleed valve. standard fuel pump, coilpacks, injectors, cams + gears, etc. i've considered the turbo upgrade options, but have something else in mind at the moment. high flow turbo will see 250ish, maybe a bit less, but if your building a dyno queen, your gonna need something like Ryan has on his 33, i think its 3582R? or if its a dyno queen, read: not for road use, you will probably benefit from a high mount turbo setup.
anyone really listened to Lily Allen's new song lyrics?
Oh he treats me with respect
He says he loves me all the time
He calls me 15 times a day
He likes to make sure that I'm fine
You know I've never met a man
who's made me feel quite so secure
He's not like all them other boys
They're all so dumb and immature
There's just one thing
that's getting in the way
When we go up to bed
you're just no good
Its such a shame
I look into your eyes
I want to get to know you
And then you make this noise
and its apparent it's all over
It's not fair
And I think you're really mean
Oh you're supposed to care
But you never make me scream
You never make me scream
Oh it's not fair
And it's really not ok
It's really not ok
It's really not ok
But all you do is take
Yeah all you do is take
Oh I lie here
in the wet patch
In the middle of the bed
I'm feeling pretty
damn hard done by
I spent ages giving head
Then I remember
all the nice things
that you ever said to me
Maybe I'm just overreacting
maybe you're the one for me
you're just no good
It's such a shame
and it's apparent it's all over
It's not fair
Oh it's not fair
It's really not ok
It's really not ok
you're just no good
It's such a shame
It's not fair
Oh it's not fair
It's really not ok
It's really not ok
