mainframe computer in head office will only let us see a few different things...i can go on carpoint.com.au ...but not carsales.com.au...
http://www.bypassthat.com/ :banana:
HAPPY BIRTHDAY DOHMAR
sex: http://www.skylinesaustralia.com/forums/R3...an-t270578.html
my missus wants to give beyonce a good going over
im not sure whether to be happy for you or worried.
ok so Nat Bass isn't the best out there, but would you kick this out of bed:
i wouldnt :banana:
Yep, what Vu said.
Note that bigger injectors and cams will not help the stock turbo necessarily make more power, as at over 200rwkw it is well out of its efficiency range. Also note that unless you are lucky, a stock turbo will not last massively long at 12psi. If I were were you I would skip the stocker, as a HKS 25/30 like mine can be had for around $1,500, and the Garrett version even cheaper (makes slightly less power though).
Also, yes you would need bigger cams and injectors (my injectors run at up to 96% making 230rwkw) to make 300rwkw unless you went for a stupidly big (read = laggy and unstreetable) turbo. Not sure how long your top end would last with 300rwkw, but seems to be a fair few people doing it around Aus.
i got 186kw when willal got there mainline dyno and i had 3" turbo back exhaust, fmic, power fc, fuel pump and boost was 13.8 psi so go figure! same as my mechanics r34 gtt he got 191kw!
with a few mods i am making 211rwkw on 12psi but ur right Son as my stock turbo is running out off puff towards the redline......but really happy down low which is very good streetable power.....but just dont know how long that the stock turbo will last....it has been running 12 psi for about 1 year now and still going strong so looking ok atm.....and my dyno figures are from Graham West Dyno's
i wouldnt :banana:
I would. I hate it when people have a wonky eye, esp on chicks. Makes me wanna slap em and say "WTF are u looking at?"
Oh and I think shes got less talent than a 3 kilogram bag of horse shit. At least the horse shit can fertilize the garden, all she does is rip of lyrics from other musicians and spends half of her songs talking because she can't sing for shit....
Yeah I'm mean, so what...
-D
How much power are you looking for Cara? 300?
just wanting to know what the max would be for stock engine before i would have to do internals, the 500rwkw will be a while before that happens, and cause my car isnt a daily anymore, i guess 250-300 would be a nice "starting point" even tho i would start off stock and go from there....i know it prob sounds weird but i would rather learn from having a stock engine and going from there really.
i mean is it worth getting this ebc thing? and what the hell is a bleed valve lol
lol Cara. EBC = Electronic Boost Controller, recommended for the power your aiming at making, forget a bleed valve for your goals. Greddy Profec B Spec II is popular and not that expensive.
If you plan to go big, do it in one go, dont buy and test turbo's etc, will be too costly. Research examples of det Neo's makign the sort of power your looking at. Why not buy a RB25/30 from R.I.P.S?
Taken from http://www.ripsltd.com/products.html:
"RB30 Stock internal long engines start at NZD$5250 with RB25 head. (suit up to 600hp and 7200 rpm)"
Happy B'day Dohmar :banana:
i find her voice extremely annoying at the moment,.
and yes happy birthday ben!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :laugh::laugh:
i wish i could damo, but the engine alone is gonna cost nearly $13,000 to do.............and im a long way off from getting that sort of money atm.
the thing is, i could get to 300rwkw and be happy with that. its hard to say until im there. just one of those things really i wont know until im there, dont get me wrong, id still love to get to 500rwkw, but at the moment its gonna be a while before that happens :D
Edited by MissR34
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
