Nengun has the pfc boost control for around 470 delivered? I guarantee Luke ENR can get it cheaper too... Both are fine, just depends if you want another device in your cabin or not i guess.
i didnt look on nengun. must do me thinks lol
Cara if your after 300 at the moment then you will something like a GT3071 + cams +porting + lots of boost and you may just still fall under 300kw but it will be more responsive that the other option which is a GT3076 which will make 300 with cams and has the potential to make more.
As for the RB25/30 build, if you are after a big power engine then do yourself a favour an go for a 26 head straight away. 26's have all the good stuff straight away like solid lifters and cams to suit as well as not having the VTC gear which you can't run with big cams. Although the NEO's have the solid setup they have a problem with an exposed oil gallery once you go over 9.25mm of lift and therefore your potential power is limited. The other good thing about the 26 heads is the availability of aftermarket parts like a wide selection of cams, valves, springs etc etc.
if i got 26 head it means im gonna have to muck around and get another ecu and whatnot when ive already got one now. was going to go custom cams anyway with the 500rwkw build, they cost the same as buying them off the shelf (around $1200)
great, another option for them to bump up prices
damn, i hope they dont shelve the mobil 98 octane... thats gonna poop on my parade (caltex dont sell any form of 98 here in SA but they do interstate - what gives? :(
-D
EXXON are going to become suppliers only have no fear Ben there will still be a mobil 98 just branded something else may even be caltex
dad said caltex make some of there own fuel but they wont have enough to supply 302 new stations with fuel
also there is a clause that they have to purchase fuel for the next 5 years
I wanna be different, so i am thinking of a Rb25/26 (RB27) conversion, i think someone in SAU:Perth did one. It had around 400rwkw, saw it in a old HPI mag, i don't wanna go to the same extent he did, but finding info is near impossible. Anyone like to help out later down the track when i blow my engine up and rebuild to a RB27?
ATM i am planning for around 250rwkw or above. I have nismo 740cc injectors on the way, have front/dump pipe & exhaust manifold, a Haltech e11v2, and still deciding on either a GT3071R or GT3076R. The guy i bought the front/dump pipe from had a GT3076R making 280rwkw on a RB25, was saying when it hit boost was just wheel spin.
Im running standard turbo at 12psi, making a little over 200rwkw with power fc, fmic, free flowing exhaust, bleed valve. standard fuel pump, coilpacks, injectors, cams + gears, etc. i've considered the turbo upgrade options, but have something else in mind at the moment. high flow turbo will see 250ish, maybe a bit less, but if your building a dyno queen, your gonna need something like Ryan has on his 33, i think its 3582R? or if its a dyno queen, read: not for road use, you will probably benefit from a high mount turbo setup.
i run a built engine and big turbo, so does that mean u im a "DYNO QUEEN"...???
so if u run a big turbo like a GT35/40 it makes u a"DYNO QUEEN"" also WTF?????????
u dont see me entering stupid dyno comps
the only reason my engine is FORGED is coz a certain "well known workshop" blew my motor up on their dyno after i spent big $$$ with them!!!!!!!!
I don't know why people say that a RB25 with a RB26 crank/rods will make a RB27 because it won't.
RB25/26/30's all have the same bore 86mm so the only difference between the engines is the stroke. So guess what, if you fit a RB26 cranks in a RB25 you end up with an RB26 because the bore and stroke is the same as an RB26.
or might hit up a 1jzgt-e for it..
mad custom work.. just want something special :(
Why don't you do what a bloke in the States did with TE27 and fit a 1UZ-fe, I'd say that you'd be the only person in Australia with a V8 keto. Having said that the CA would still make more power.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
