I don't know why people say that a RB25 with a RB26 crank/rods will make a RB27 because it won't.
RB25/26/30's all have the same bore 86mm so the only difference between the engines is the stroke. So guess what, if you fit a RB26 cranks in a RB25 you end up with an RB26 because the bore and stroke is the same as an RB26.
I believe to make a RB27 out of a RB25 you also need to do a 2mm bore as well so you get the extra displacement. I am not too sure, as finding info on this is near impossible for me, whenever i really search its pretty much about the Jun or Tomei stoker kits.
Your car is hot.
Cheers mate :(
yeah ive been in a 300rwkw car and loved every minute of it. was an amazing feeling :)
nice plates btw :)
Good stuff, i just wanted to know if you knew what sort of power you would be getting yourself into. Even 300kw in a rwd car is wheel spin city, 500rwkw would just be pointless i recon.
wrong the stroke has to be longer since the bore is the same its the only way to change the capacity
Why don't you do what a bloke in the States did with TE27 and fit a 1UZ-fe, I'd say that you'd be the only person in Australia with a V8 keto. Having said that the CA would still make more power.
i believe there is another guy's that have done it
oh yeah but even once the car is making 500rwkw will be dyno queen i think
but then i could be happy with 300rwkw
i wont know till im there really :(
Good to see we're on the same page because that's what i said. If you fit an RB26 crank in to a RB25 block you end up with a RB26, because the bore and stroke will then be the same as an RB26.
Edited by D_Stirls
If i was to built a dyno car it would have to make 1000hp minimum.
problem is, 500rwk from a 2.5 litre (turbo) will be totally gutless on the street and a stock standard RB25 will blow you away at the lights
It'll be an absolute pig to drive around town and will be gutless up until 5000rpm........from there it's wheel spin city all the way to 9000rpm and lots of broken bits to sweep up behind you unfortunately
it would be RB25/30
and ive been told that having the RB30 bottom end will help a lot with torque?
The way in which you will have to set up your head to get 1000rwhp means that you will lose all of the bottom end torque that you will have gained by fitting a 3 litre. having said that you will have more than a 2.5 litre.
I think you need to have a good look at what you want from this build and then going for broke because you can't have your cake and eat it too. If you want low down torque go back to looking at a Supercharger as there are S/Chargers that will make 1000hp. Or better yet look at fitting a VH45DE with a charger or twin turbos.
Either way once you start you'd better have some money behind you because building a 1000hp engine won't give you much if any change out of $40,000.
Edited by D_Stirls
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
