I don't know why people say that a RB25 with a RB26 crank/rods will make a RB27 because it won't.
RB25/26/30's all have the same bore 86mm so the only difference between the engines is the stroke. So guess what, if you fit a RB26 cranks in a RB25 you end up with an RB26 because the bore and stroke is the same as an RB26.
I believe to make a RB27 out of a RB25 you also need to do a 2mm bore as well so you get the extra displacement. I am not too sure, as finding info on this is near impossible for me, whenever i really search its pretty much about the Jun or Tomei stoker kits.
Your car is hot.
Cheers mate :(
yeah ive been in a 300rwkw car and loved every minute of it. was an amazing feeling :)
nice plates btw :)
Good stuff, i just wanted to know if you knew what sort of power you would be getting yourself into. Even 300kw in a rwd car is wheel spin city, 500rwkw would just be pointless i recon.
wrong the stroke has to be longer since the bore is the same its the only way to change the capacity
Why don't you do what a bloke in the States did with TE27 and fit a 1UZ-fe, I'd say that you'd be the only person in Australia with a V8 keto. Having said that the CA would still make more power.
i believe there is another guy's that have done it
oh yeah but even once the car is making 500rwkw will be dyno queen i think
but then i could be happy with 300rwkw
i wont know till im there really :(
Good to see we're on the same page because that's what i said. If you fit an RB26 crank in to a RB25 block you end up with a RB26, because the bore and stroke will then be the same as an RB26.
Edited by D_Stirls
If i was to built a dyno car it would have to make 1000hp minimum.
problem is, 500rwk from a 2.5 litre (turbo) will be totally gutless on the street and a stock standard RB25 will blow you away at the lights
It'll be an absolute pig to drive around town and will be gutless up until 5000rpm........from there it's wheel spin city all the way to 9000rpm and lots of broken bits to sweep up behind you unfortunately
it would be RB25/30
and ive been told that having the RB30 bottom end will help a lot with torque?
The way in which you will have to set up your head to get 1000rwhp means that you will lose all of the bottom end torque that you will have gained by fitting a 3 litre. having said that you will have more than a 2.5 litre.
I think you need to have a good look at what you want from this build and then going for broke because you can't have your cake and eat it too. If you want low down torque go back to looking at a Supercharger as there are S/Chargers that will make 1000hp. Or better yet look at fitting a VH45DE with a charger or twin turbos.
Either way once you start you'd better have some money behind you because building a 1000hp engine won't give you much if any change out of $40,000.
Edited by D_Stirls
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
