i thought government workers didnt do any work??? or is that council workers...lol
Come on man dont be hating on the Govt employees....we i mean i do a lot of work just that the networks are slow in the country side what can i do
Check out nurses.
blue mesh packaging now includes the following message
WARNING: MAY LEAVE PHYSICAL/EMOTIONAL SCARRING. RICE MODS PTY LTD IS NOT RESPONSIBLE FOR ANY DAMAGE PHYSICLY OR EMOTIONALLY THIS PRODUCT MAY HAVE
WARNING: VIEWER DISCRETION IS ADIVISED, THE SIGHT OF THIS MESH MAY OFFEND SOME VIEWERS
you'll never hear the end of this :P
has become the most common butt end of all our jokes :P
Edited by Inline 6
I'm sooooo going to get something like that made up for when the Stagea is in car shows :P
Warning: Blue mesh may cause Retinitis Pigmentosa (retina blindness) and has been known to cause emotional scarring (lackness of HTFU). "Fear the Blue Mesh" is not responsible for any physical or emotional damages arising from the use or misuse of blue mesh. Please observe from a safe distance at all times.
:P
Edited by RubyRS4
ever worked in a hospital?? i think they are a myth... most nurses are actually rather old and not what i'd call hot. however the traniee doctors... giddy up!!!
Thats only true if your stuck in a metro hospital Luke heheheh :thumbsup:
Country hospitals seem to have more hot nurses then city.....interns umm some of them can be quite hot
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
