have you got the gear selector in 3rd :(
OOO ouch...rofl.....you sir have insulted my intelligence...i challenge you to a duel!!!!
"glove slap..baby glove slap, glove slap..i dont take crap..."
rofl....the drugs seem to be working
Daniel...lonsdale wheel aligners...go see Chris...opposite the lonsdale pub...he's been in the business basically since the model t ford and i wouldnt trust anyone else down south with wheel aligning my cars...plus he's an ultra nice guy...
8 lindsay road lonsdale, 8381-1003...tell him Ben from motor traders sent ya
Edited by nugzy31
Ruby give Autotrans a call they are a specialist in auto transmissions they might be able to give you an idea on what would be the issue.
for a second i thought you were telling ruby to call AUTOBARN a call :(
my friend has a r34 gtt.
He wants to know any rough estimates of how much power he should be pushing before he heads to the dyno.
Rb25 neo turbo
Blitz FMIC
Oil cooler
Z32 AFM
full exhaust
profec b 14 pounds boost
HKS pod
Power FC
Cheers.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
