have you got the gear selector in 3rd :(
OOO ouch...rofl.....you sir have insulted my intelligence...i challenge you to a duel!!!!
"glove slap..baby glove slap, glove slap..i dont take crap..."
rofl....the drugs seem to be working
Daniel...lonsdale wheel aligners...go see Chris...opposite the lonsdale pub...he's been in the business basically since the model t ford and i wouldnt trust anyone else down south with wheel aligning my cars...plus he's an ultra nice guy...
8 lindsay road lonsdale, 8381-1003...tell him Ben from motor traders sent ya
Edited by nugzy31
Ruby give Autotrans a call they are a specialist in auto transmissions they might be able to give you an idea on what would be the issue.
for a second i thought you were telling ruby to call AUTOBARN a call :(
my friend has a r34 gtt.
He wants to know any rough estimates of how much power he should be pushing before he heads to the dyno.
Rb25 neo turbo
Blitz FMIC
Oil cooler
Z32 AFM
full exhaust
profec b 14 pounds boost
HKS pod
Power FC
Cheers.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
