i wouldnt have changed it carl, the guys communication was shit and i would have left it as you had it before.
i did get a few responses that were helpfull initially, but she turned sour, and tried to make it a shit fight which i wasnt gonna have.
i did wanna sh!t can her totally, but meh, karma and all that
hey Pete, got your message but didn't have time to call you back. Sucks you couldn't come to Kadina - bloody weak excuse though! :blink: You missed out on a huge one bud - was an absolutely blast, despite the weather.
yeah sorry dude, would've loved to have come on the trip.
As you can see, by not being around for the last couple of days, I've been under the pump with work and trying to get this shed organized.....too many crooks to cook and not enough days in the week unfortunately. :)
Only problem is that 90% of the kits look fkn gay!
Too true Steve and moreso on 33's for some reason......obviously very nice looking 33 Roo but too many are ruined with bad kits.
For some reason 32's & 34's are more forgiving with wrong kits.
Just got ULX 110 oil to try.
Awesome. Gotta carry it to the train station. Forgot about that!
It's good gear Penny (I use it all the time).....the state supplier is a good mate of mine and worked with me and Anthony Norris (Grande Auto) many years ago.
Many top drag racers use the stuff too.
Well, picking up another front bar to replace the 'hacked' front bar this morning. Its not too bad on the eyes ... but its a temp anyway for now. Tracy and I have a buyer for our house, so after settlement the 33 will get a decent kit. I'm happy for peeps to shot me pics of what they think looks noice ... keep in mind its a 4 door :P
We're thinking a suitable/subtle front bar (Aero type R or similar), type M skirts modded to fit, and pods for the rear.
GTR front bar/guards + 34GTR wheels. Don't even think about mesh :P
Giving up drinking.
Especially when not eating tea before hand.
Weak, some of the best nights were had boozing on an empty stomach.
NB I have no memory of said nights, so they default to being awesome unless I hear otherwise the next day.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
