just spent about 500bux on the sil getting it ready for paint.
pick it up and a third of the way home the water pump dies.
now its getting another 500-600bux worth of crap on it. 52mm alloy rad being put on since the old ones coming off anyway.
then goes back for a custom fmic install haha going to mount it upside down to sorten the pipe work and get better throttle response.
after that gtr injectors and rb20 afm and a retune and i should be happy with the power side :s
got a bride zeta III to pick up off my mate and all thats left is a cage :)
i hate cars ;)
Edited by Import S13
Ruby please change your avatar. I'm soooo sick of that homo comic male thrusting his groin on my screen that I skip all your posts and the ones directly above and below it.
It's worse than the blue mesh... at least I don't see that in my own home.
haha i cant keep my eyes off it :)
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
