Depends on if its seized or cross threaded.
True. I've always snapped bolts over-tightening, never getting the farker out. If it's cross threaded or seized in there then it's a drill and tap job..... easy enough to do if you have the correct size drill bit and tap :blush:
Well its one of the coilpack bolts, the very front one (closest to bonnet). The 34 doesn't have a removable cradle like the 32 and 33 do, which would make for an easy removal. Captain thread is like the only professional removal service, and hes $99 for my suburb.
Just pay the $99
naw i got guts of steel brew, matter of fact this one was pretty mild but the beer is good
-D
yo, is there any place u can get fresh cinnamon donuts at midnight?
failing that a jam berlinner
i has a pregnant woman here craving, and then theres me
haha
-D
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
