i think im having mental problems..... i quite fancy the new holden cruze :)
Had good close look at one at work, they're not actually too bad Craig. For the price the turbo diesel would be the go!
Oh and Matty, nice mud slingers mate :)
Yeah top of the line model is similar in fit out to the old CDXI Vectra's, heated leather seats, heated exterior mirrors, climate control (dual zone if i remember) 17" alloys, god i sound like a salesman !
Which clubs did you buy?
Dave I don't think you have to be old fashioned to find that unacceptable :)
They are top flite clubs Steve.....top flite has been owned by calaway for a while now so they are calaway made lol
Craig go the TRD Aurion mate.....in love with that car
