They are top flite clubs Steve.....top flite has been owned by calaway for a while now so they are calaway made lol
Nice 1. What shafts are in them?
oh and Dave, prob a good thing I wasn't with you you last night bud.
+1
Matty31 and anyone else that cares - Repco have 20% off nearly everything in store today.
Ok looking at getting a power fc and a new turbo (mines starting to make bearing noise) in the next month or 2. Just wondering if its better to fit both at once or one at a time. I know it means two lots of tunning, but figure i can save myself some cash on the turbo install and do it my self.
James get it done both at the same time.....its cheaper that way i reackon mate
steve that info i dont know.....but it certainly improved my game on the first go at it mate.....so happy with it
I was looking this morning at a Autometer boost gauge at Repco, thing is it doesn't have the mounting cup and they don't stock the cup..... Any mounting ideas other than having to cut a 2 1/16" hole in the dash somewhere (which isn't going to happen!)?
Got a black mounting cup here Steve if you want, $20 it yours
Cheers will keep it in mind, but after having a look around I'm kind of liking the GTR single DIN setup. That way I get rid of the ugly DIN pocket that doesn't quite fit correctly.
Only problem is Defi ($$$$) are the only aftermarket 3 gauge single DIN setups I've come across so far!!!!! Will keep looking....
Fit the Power FC yourself. It's very easy. You wont need a tune as the PFC has a base map already. Unless you have made changes to turbo or injectors. Then save for yuor turbo, injectors and THEN get it tuned.
The FC is second had, had a plug in test on thursday. Not sure of mods it was tuned for though, but at least it started! Was so tempting to say "leave it in there". Slightly high idle on start up, then rough idle, possibly tuned for bigger injectors. Think that my be the way i'll go Ryan :)
Is there a way you can reset then to the base tune?
Anyone watching channel 10 at the moment, they're showing the Isle of Man TT.
That S*#T is crazy, No regard for ones life.
omg i got dizzy watching that front camera view going through those little villages, hills and jumps at 160mph. Couldn't believe it.
yes do an initialization in the settings menu. No hassles what so ever.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
