They are top flite clubs Steve.....top flite has been owned by calaway for a while now so they are calaway made lol
Nice 1. What shafts are in them?
oh and Dave, prob a good thing I wasn't with you you last night bud.
+1
Matty31 and anyone else that cares - Repco have 20% off nearly everything in store today.
Ok looking at getting a power fc and a new turbo (mines starting to make bearing noise) in the next month or 2. Just wondering if its better to fit both at once or one at a time. I know it means two lots of tunning, but figure i can save myself some cash on the turbo install and do it my self.
James get it done both at the same time.....its cheaper that way i reackon mate
steve that info i dont know.....but it certainly improved my game on the first go at it mate.....so happy with it
I was looking this morning at a Autometer boost gauge at Repco, thing is it doesn't have the mounting cup and they don't stock the cup..... Any mounting ideas other than having to cut a 2 1/16" hole in the dash somewhere (which isn't going to happen!)?
Got a black mounting cup here Steve if you want, $20 it yours
Cheers will keep it in mind, but after having a look around I'm kind of liking the GTR single DIN setup. That way I get rid of the ugly DIN pocket that doesn't quite fit correctly.
Only problem is Defi ($$$$) are the only aftermarket 3 gauge single DIN setups I've come across so far!!!!! Will keep looking....
Fit the Power FC yourself. It's very easy. You wont need a tune as the PFC has a base map already. Unless you have made changes to turbo or injectors. Then save for yuor turbo, injectors and THEN get it tuned.
The FC is second had, had a plug in test on thursday. Not sure of mods it was tuned for though, but at least it started! Was so tempting to say "leave it in there". Slightly high idle on start up, then rough idle, possibly tuned for bigger injectors. Think that my be the way i'll go Ryan :)
Is there a way you can reset then to the base tune?
Anyone watching channel 10 at the moment, they're showing the Isle of Man TT.
That S*#T is crazy, No regard for ones life.
omg i got dizzy watching that front camera view going through those little villages, hills and jumps at 160mph. Couldn't believe it.
yes do an initialization in the settings menu. No hassles what so ever.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
