EBC's control boost & make the boost come on alot more harder then a T Peice will and defeinatly control boost spike especially if your looking at holding decent power where 1 - 2 psi extra will cause your car to detonate and end up smashing pistons.
If you can afford it and are looking at running more then 10 - 12psi a EBC is definatly the thing to buy.
Buy a apexi powerFC boost controller that works in conjunction with a powerFC if thats the ECU your going to be running, stealth as, its easy to hide the boost solenoid in the engine bay and can all be controlled using the hand controller or laptop via the tuner I think,
Thats what I am going for anyways. I will have a bleed valve forsale soon if your keen Cara - Its a turbosmart one lol
EBC's have flashing lights!!!!
oh how exciting
JK has said to get a ebc......but i not sure whats the best for what im doing, ive seen a turbosmart single stage boost controller....would that be ok?
turbosmart eh? hmm, last i looked into turbosmart, well... yeah. say no more i spose.
once i get my hybrid tuned, ill let you know how it goes.
i dont think id be runnign anywhere near 12psi anyway
maybe only 7-8psi
or, you could get a DET and run 12psi.
You don't need a boost controller for 7psi >_>
+1 what he said
actuators come in all sorts of settings but I know that 7, 14 and 20psi are rather common
i have stock gtr with stock turbos but the ebc lets me run to 14, and when i get my n1's I'll be able to go to 20 no sweat
if you're running steel turbines I don't see why you wouldnt be running 14 at a minimum (unless the neos cannot hack it? I wouldnt know tbh), and if you are going to run 14, the ebc will make a noticable difference
-D
She wont be able to fun F all boost cos the engine is an NA with high compression, I think even 7 psi would be giving an NA a pretty hard time.
fair enough. consideirng the 25det engine + loom isnt that pricey, the det does make sense considering the cost/hassle to fit the turbo onto the NA
-D
ive decided that my soldering iron sucks.
EDIT: not to mention references to "African Americans"
LOL, you're asking for a stick up your bum Dave
it is possibly that may have too much bad language... hmmm...
Edited by SLED
Dohmar - Where you getting your turbos from and what price are you looking at?
Can you PM me. I will be doing the same very shortly I hope lol :D.
Lmfao, I love it Dave!
Edited by Weezy
HAHAHAHAHAHAAHAHAHAHAHAHAHAHAHAAHHAAHAHAHAHAHAHAHAHAAHAAAAAAAAAAAARRRRDE HAR HAR!!!! funny funny stuff.......also...LAST DAY B4 TWO WEEKS OFF!!!!!! WOOOOOOOOOOOOOOOO......i'll be up at my mates shed again tonight....fitting my fuel tank so i can actually boost again...havent been sideways all week......i miss my boost
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
