EBC's control boost & make the boost come on alot more harder then a T Peice will and defeinatly control boost spike especially if your looking at holding decent power where 1 - 2 psi extra will cause your car to detonate and end up smashing pistons.
If you can afford it and are looking at running more then 10 - 12psi a EBC is definatly the thing to buy.
Buy a apexi powerFC boost controller that works in conjunction with a powerFC if thats the ECU your going to be running, stealth as, its easy to hide the boost solenoid in the engine bay and can all be controlled using the hand controller or laptop via the tuner I think,
Thats what I am going for anyways. I will have a bleed valve forsale soon if your keen Cara - Its a turbosmart one lol
EBC's have flashing lights!!!!
oh how exciting
JK has said to get a ebc......but i not sure whats the best for what im doing, ive seen a turbosmart single stage boost controller....would that be ok?
turbosmart eh? hmm, last i looked into turbosmart, well... yeah. say no more i spose.
once i get my hybrid tuned, ill let you know how it goes.
i dont think id be runnign anywhere near 12psi anyway
maybe only 7-8psi
or, you could get a DET and run 12psi.
You don't need a boost controller for 7psi >_>
+1 what he said
actuators come in all sorts of settings but I know that 7, 14 and 20psi are rather common
i have stock gtr with stock turbos but the ebc lets me run to 14, and when i get my n1's I'll be able to go to 20 no sweat
if you're running steel turbines I don't see why you wouldnt be running 14 at a minimum (unless the neos cannot hack it? I wouldnt know tbh), and if you are going to run 14, the ebc will make a noticable difference
-D
She wont be able to fun F all boost cos the engine is an NA with high compression, I think even 7 psi would be giving an NA a pretty hard time.
fair enough. consideirng the 25det engine + loom isnt that pricey, the det does make sense considering the cost/hassle to fit the turbo onto the NA
-D
ive decided that my soldering iron sucks.
EDIT: not to mention references to "African Americans"
LOL, you're asking for a stick up your bum Dave
it is possibly that may have too much bad language... hmmm...
Edited by SLED
Dohmar - Where you getting your turbos from and what price are you looking at?
Can you PM me. I will be doing the same very shortly I hope lol :D.
Lmfao, I love it Dave!
Edited by Weezy
HAHAHAHAHAHAAHAHAHAHAHAHAHAHAHAAHHAAHAHAHAHAHAHAHAHAAHAAAAAAAAAAAARRRRDE HAR HAR!!!! funny funny stuff.......also...LAST DAY B4 TWO WEEKS OFF!!!!!! WOOOOOOOOOOOOOOOO......i'll be up at my mates shed again tonight....fitting my fuel tank so i can actually boost again...havent been sideways all week......i miss my boost
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
