:thumbsup: Decision made then!
See, there's $400 saved already. Only $1600 to front up now. Sell your body on the streets, you'll only be looking at another $1590 or so after that, every little bit helps
lol. ive got til monday or something to make a choice... i dunno. ill see how much the tax man wants to give me and go from there.
hahah.
two chicks from my school were strippers too.
get this :
Both underage at the time. 17 each.
One was at crazyhorse. the other was at 108s. or whatever it was called.
Was in the paper. big trouble.
lol were they twins? might be same 1s
Calling Chad, calling Chad......where are you??
Are you anywhere near my house tomorrow?
Need some welding advice bud (gates & RSJ's for a retaining wall).......would get my Dad who's a Boilermaker but he's fallen very ill unfortunately.
I'm starting work at 6am tomorrow, so i should be finished work by about 3ish. I'll give you a call when i finish and see where your at.
Dave go for a GT28RS, if you keep the boost below 12 psi you can get around without a tune for the time being. I would just do a run on the dyno to see what the AFR's are like though before you push it too much, but that'll only cost you $50. There is no point rebuilding the T28 when you will only get $4-500 when you go to sell it. you might as well put the rebuild money towards the GT28RS.
A 2871 is a bit to big to get around on without a tune, you would have to keep it below 9 psi and it would be dowie as and you wouldn't like it.
What are you still doing up homo?
resetting the body clock for nightshift.
rebuilds only costing $450...
how much does a 28RS go for anyways?
well stock cars are welcome to join in with the club displays - you dont have to have a car that is a show car to be part of it all :rofl:
ok so let me know when something comes along and we will see if we can make it.
only thing is the car needs new coils so i dont want to drive it realy far until thats done :thumbsup:
he he i got in trouble for spending $300 on headlight globes :P supposed to be paying for a wedding
only thing is the car needs new coils so i dont want to drive it realy far until thats done :(
he he i got in trouble for spending $300 on headlight globes :) supposed to be paying for a wedding
dont wanna buy some standard springs and shocks by any chance? :blush:
btw Talbs, i beat you in dream team last week :blush:
Did I make it into that group you setup? I should really go in there and see what it's all about, at the moment I've been just trading players.... and congrats I didn't know you beat me :(
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
