http://news.ninemsn.com.au/national/838383...rs-tail-cut-off
if i ever found who did this, id cut there fackin dick off!!! flamin mongrels
sick f**kers who obviously have no conscience... what compels these sick mentally disturbed bastards is beyond me!
thats just plain wrong.......i rekon they should cut the ears off the person that did this with scissors and see how they feel.
cut their balls off and let em bleed out
not before getting kicked into a coma imho
-D
Awww I love dogs... pisses me off reading that! Someones got to be seriously screwed up in the head to be doing that shit to a puppy.
I got a vietnamese cookbook here yo, "101 ways to Wok your Dog"
Ive made a couple recipes and they pretty good eh lols....more bark and less bite with a ruff texture
-D
I hate to tell you guys but apart from the scissors part it's common place with some breeds to cut their ears and dock their talls.
How do you think Doberman ears get from being floppy when they are a puppy;
To being like this;
sweet. ill check em out on my next day off. rough idea on price? (yes, i know their number is right there. :banana:)
im thinking jdm 440's might be a tad small. need some headroom for more power...
... not that ill be aiming for more power, because modifications are bad and illegal, and kill people, abort pregnancies, crush kittens, and club baby seals. :banana:
Edited by scandyflick
(snip)
To being like this;
(snip)
it used to be common and legal but it is now and has been for a few years illegal to dock tails and prick ears or rotti's, doderman's etc.
but this doesn't mean it's still not going on. i've heard of a few places that still do it :P
There are some problems with high flowed injectors not having a good spray parttern and therefore bad atomisation.
When you can get 500>550cc for around the $300 mark why bother.
http://cgi.ebay.com.au/Fuel-Injector-SUBAR...p3286.m20.l1116
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
