so whats everyone been up to today?
Having a busy as f**k day as i am trying to finish off everything down here in KI and be home by tomorrow....hooray for catching the 10.30 morning flight back
lul, i think ill stay local with my mechanics.
bah, 5 stud seems more trouble than its worth, might as well just upgrade the rotors, calipers and pads, and find a decent set of 4 stud rims.
might grab these
SSR Mesh 15x7+0
I really love when the Ebay fairy visits and brings me gifts :down:
My new real carbon fibre intake tube
just had a look just then, you can get orange ones too.. very cheap to tidy up your engine bay with.. not sure how good it supports the heat though.
**the ones i seen are the sticker ones.. look-a-like carbon fibre
Edited by wannabeer33
