anyone know the causes of hard to start rb25? its cranks over but takes 5-6 times to slowly get running.. once its running if i turn it off then back on its fine..
its like only once its been sitting for a few hours!?
any ideas?
No worries champ thanks i'll keep that in mind....plastics or metal??
Kinda in limbo atm not sure exactly WHEN im going to be outta a job so its all up in the air atm!
Plastic. Basically pellets get melted down through a machine that turns it into piping.. Comes down the line and your job is to coil it up. Pretty simple.
Jarrad has a hard day ahead then? :/
Wayne and I both work in Extrusion so we got the day off because there is too much pipe out in the yard so the store men need a whole day to catch up. Just what happens when Wayne and I are working..
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
