Anyone know a good reliable plumber?
Can't find a plumber who will come out and give me a quote on my house extension!!! :/
Nearly everyone I called say they only do maintenance, or are not available in my area!!!
I've gone thru over 20 online and nothing ...
:P
I'm ready to do the bloody thing myself.
[end rant]
reliable plumber...? i wasnt aware such a thing existed.
took the 200 for a quick strap with weezy and talbo, aside from the front left corner rubbing on something up in the guard, its mint.
never once did the front end wash wide or squeal, freakin brilliant.
also got a "nice offset" comment from a cop on the way home, lol.
Edited by scandyflick
What size wheel and tire combo you running?
I bought some KUMHO KU71's off of Option1. I was supposed to get the KU36 semi but they didn't have my sizing and it was going to be a month wait (which at the time I didn't want because I was going to be selling the XD9's). They stretch alright?
tell him to hurry up and put those pics in here. need some pics for my threads!
haha, yeah, could use an extra half inch... or a 10mm spacer... if the rears sat as well as the fronts id be laughin.
size matters :)
Can't find a plumber who will come out and give me a quote on my house extension!!! :)
:ermm:
[end rant]
Give Fusco builders a call on Monday. One of the brothers is a plumber, but I'm not 100% sure he does anything outside of their own developments. If you don't have any luck talking to them I know one of them (mrs business partner) and can ask, if you prefer me to ask let me know because I'll see him tonight when I pick the mrs up from work.
Dave I reckon it looks great, just need 215 on the front or 225 all round.
i want to LOOK at her ass, and possibly touch and do unspeakable things to it, you two ^^ can have girls assess if you want..
Haha... I got a feeling you know exactly what we were talking about :ermm:
Incidentally, I just watched her on ACA :)
problem; front tyres rubbing on just about everything.
solution; remove inner guards, and demon camber.
new problem; tyre wear...?
new solution; anyone have a heat gun?
theres a special chair in hell reserved for me because of the things id do to that...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
