So yeah, my brakes are shite. and with the RDA slotted rotors im getting, what is the general opinion on EBC "Yellowstuff" pads? Mainly for daily use and driving through the hills, but i want some decent pads to compliment the rotors, any help would be great.
not for daily use bud..........maybe redstuff is as far as you'd want to go
get some QFM HPXs or A1RMs .... awesome stopping power, little brake dust and little rotor wear .... the different coloured 'stuff' pads eat rotors for breakfast and have too much dust IMHO.
As Andrew has said you can't go past that QFM pads, I'm using the A1RM pads, they have unbelievable cold bite (I seriously couldn't believe it), and i have used them at Mallala and pulling low 1:20's and for 15 minutes and never had any fade. Also done 2 modern Reg' events and i still have another 2 days left in the pads, that's with a few hills runs as well.
They have a 1/2 price rears deal (through GSR RallySport, who's a trader on here) as well and i got free postage as well so that's front and rear 780 degree pads for $190 posted.
Edited by D_Stirls
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
