stanza struts are almost a straight bolt in.....brake upgrade...then you can drop in a L16....or a L20 with a 16 rocker cover...the car is still legal.....cheap power upgrade.....mind you the a series motors take a hell of a lot of beating.......just fix the rust in the sill panels before it ends up at grand auto....
had a bit of a lol moment this morning;
went down to the local bp to fill up, saw a cop car sitting in one of the parking bays as soon as i pulled up, whatever, might get defected, but how f**kin sus would it look if i just rolled out as soon as i rolled in?
whatever.
took my time, filled up, checked my tyres, cleaned my windows, you know, same shit any other responsible motorist would do when theyre filling up. cop cars still there. hmm.
so i wander in and the first thing i hear from the attendant (shes talking to the cops) "... probably make the front page of the saturday paper driving a car like that."
i stop dead in my tracks, did she just say what i thought she just said? she wouldnt be comparing me to the magill road morons just because of the car i drive... would she?
so i ask that exact question, i phrase it nice and polite, not an accusation, and im met by her and the 2 cops with stunned silence, almost like some explorer would be if he stumbled upon a previously undiscovered tribe, like they werent expecting me to be able to speak english, after a few moments of that, the younger cop replies; "... yeah."
launch into a big spiel about judging books by their covers, about believing everything their spoon fed by the media, and how not all performance car owners are retards who think 150 in a residential is fine.
i left smiling, they continued to stand there, dumbstruck. it was awesome.
and on a sadder note, after 9 months of service, my parrot is no more, fell of somewhere on my travels today;
RIP. :banana:
Edited by scandyflick
whatever.
so i wander in and the first thing i hear from the attended (shes talking to the cops) "... probably make the front page of the saturday paper driving a car like that."
RIP. :banana:
Gold...is that the BP's on main north road???
RIP parrot.....you have just lost major performance dave
yeah, i lost at least 40 niggawatts there.
its being replaced with a little devil i bought at the fringe though, so i should make at least half back.
just found out the replacement cost for my headlight...........$1752 :banana:
seriously,
http://www.japaneseimportspares.com.au/itemdetails/2095
jis, brand new, suit gtt, $615.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
