With you on that one Shane! That place is always crawling with cops, cant say i've ever had the remarks passed that Dave did though!
Most definatly have not luckily!! Thats why i generally don't goto the smaller one if i can help it
Oil cooler atleast if its gona be limiter bashing for a few laps lol,
Where is Cubes these days? He used to post on heaps of forums now hes just fallen of the face of the planet?
wont be bashin the limiter weezy :)
have it in 3rd and feather the throttle :D
Mitch, a mate of mine works at JMS, I highly suggest you go with their deal, they will be making 9/10ths of f**k all just to get you back on road.
Wayne, Cubes left a while ago now due to many reasons, he still posts from time to time, but under a different user name
Put simply, I wouldn't take it out. Definitely be considering atleast a FMIC, probably even oil cooler.
fmic isnt a super essential if your not going out there and competing et. neither is a oil cooler.
both are great pre-cautions and do great on the track but in this weather and the fact that your only doing 30min intervals you'll be fine.
i was running the standard ca non turbo rad and no oil cooler and a custom supra fmic setup till recently for a few track days and it worked fine. the 30min breaks between drifts were more then enough of a cool down.
if you plan on going out there more often, then i'd look into the above things (mainly just a fmic) and you'll be alright.
Edited by Import S13
Howdy guys, bought another car to get from to and from work during the week, leave the skyline for the weekend :D
Its pretty awesome and starts first crank n' whatever :)
im pretty sure i was driving behind you going up brighton rd in the 60 zone into the 80 zone.
i was in the white pulsar sadan in the back seat having a beer :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
