yeah i have a HKS cooler but no piping for it as it was custom shit from my gtr motor , im getting a oil cooler eventually aswell
just need to get out there sliding asap !
Rush into it and you'll have another blown motor
Signed up another bunch of members tonight. New membership cards are coming to all SAU:SA members.
And a heads up ... get in quick because the next two membership numbers are #0033 and #0034 :D
(#0035 is already taken ... I had my arm twisted by "he who waves the ban stick")
Hmmmmmm, do i want #0033...how much is membership?
Membership is $30 per year + $15 once off admin charge = $45 (plus +$5 for associate member card for partner).
:D
nah for the 34, gonna shove that on for a grip session when i get everything sorted. 31 would need a bit of work to be track ready, and since im keeping the 34, gonna have a few fun laps in it :D
be a pal, you can buy some coilovers for the 33 while youre there. :D
I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
