yeah i have a HKS cooler but no piping for it as it was custom shit from my gtr motor , im getting a oil cooler eventually aswell
just need to get out there sliding asap !
Rush into it and you'll have another blown motor
Signed up another bunch of members tonight. New membership cards are coming to all SAU:SA members.
And a heads up ... get in quick because the next two membership numbers are #0033 and #0034 :D
(#0035 is already taken ... I had my arm twisted by "he who waves the ban stick")
Hmmmmmm, do i want #0033...how much is membership?
Membership is $30 per year + $15 once off admin charge = $45 (plus +$5 for associate member card for partner).
:D
nah for the 34, gonna shove that on for a grip session when i get everything sorted. 31 would need a bit of work to be track ready, and since im keeping the 34, gonna have a few fun laps in it :D
be a pal, you can buy some coilovers for the 33 while youre there. :D
I wish! Don't know whether to go for a FMIC first or suspension. All too hard cause I don't want to cut reo and cop a defect either!!!
I got to go speak to a suspension expert about lowering my car because I definitely don't want a harsh ride, being a daily driver. If I can get it 25-30mm lower with spring rates very similar to what they are now and of course correct camber I'll be happy.... don't really think it needs to be any lower than that.
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
