yep! i get sucked in to TV series, i gotta get Burn Notice season 2 back out to watch. i know its on tv at the moment, but i prefer watching seasons all in one session :D
same here. love Burn notice too, quality show! it's up to episode 9 in season 3 atm, with a total of 16. the last 7 episodes will be run in the winter season (in the US - so December). E9 is a good mid-season ending - leaves you in suspense!
Holy crap, a SD camera card 2 terabytes in size is available soon. lol
SDXC
The Secure Digital Extended Capacity (SDXC) format was unveiled at CES 2009. The maximum capacity defined for SDXC cards is 2 TB (2048 GB). SDHC cards also have a maximum capacity of 2 TB based on the card data structures, but this is artificially limited to 32 GB by the SD 2.0 document.
The maximum transfer rate of SDXC was announced as 104 MB/s, with plans to increase it to 300 MB/s in the future. The SDXC specification has selected Microsoft's proprietary exFAT file system as the standard for this memory card format;[24][25][26] however, as with SDHC and SD, it is possible to use another filesystem such as FAT32 or ext2.
One morning at a doctor's surgery a patient arrives complaining of serious back-pain. The doctor examines him and asks him "OK, what happened to your back?"
The patient replies "You know that I work for a local night club? This morning I got home to my apartment early and heard a noise in my bedroom. On entering I knew someone had been with my wife and the balcony door was open. I rushed out the balcony door and did not find anyone. As I looked down from the balcony I saw a man running out and he was dressing himself. I grabbed the fridge and threw it at him,That's how I strained my back"
The 2nd patient arrives looking as if he has been in a car wreck. The doctor said "My previous patient looked bad, but you look terrible.What happened to you?"
He replied, "You know I have been unemployed for a while now. Today was the first day at my new job. I forgot to set my alarm and was running late. I was running out of the building, getting dressed at the same time, and you
won't believe it but I was hit by a fridge."
The 3rd patient arrives; he looks even worse than the other two patients do. The doctor is shocked.
Again asks, "What happened to youuuuuu.....?"
"Well I was sitting in a fridge & someone threw it from the 3rd floor"
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
