Got a spare 23k burning a hole your pocket ?????
- Brand New R33 GTR N1 Long Motor
- Fully Assembled
- All Components Brand new
- Ready to Install
- 500PS Package
Engine Package Includes:
- Front Differential
- Sump
- Tomei 1.2mm Metal Head Gasket
- Tomei Metal Intake Manifold Gaskets
- Tomei Metal Exhaust Manifold Gaskets
- Tomei Poncam Type B Camshafts (260 Deg/9.15mm)
- JJR Adjustable Cam Gears
- Sard 700cc Injectors
- Sard Dual Entry Fuel Rail
- HPI Stainless Dump Pipes
- SSI Premium Stainless Exhaust Manifolds
- HKS GT-SS Twin Turbo Kit
- Gates Strengthened Silicone Timing Belt
- Trust Clear Timing Belt Cover
- Nismo Engine Oil Cooler Sandwich Plate
- Nismo Engine Mounts
- JJR Direct Ignition Coil Packs
- NGK BCPR6EIX-11 Iridium Spark Plug Set
- N1 Oil Pump
- N1 Water Pump
- Cooling-Pro Silicone Water Hose Set
- Ceramic Coated Plenum
- R34 GTR NUR Coil Cover Emblem
- HKS Oil Cap
- New Genuine Nissan Air Regulator
Engine Internal Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1
Pistons: N1
Conrods: N1
Just Jap
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
I also have some 17x7 rims that you can have for $550 they are copies of the rims i have on my 180 (Volk GT-P's), they have 3 legal tyres on them and one that has to much camber wear. I was going to use the 17's fro track rims but now that i'm fitting a RB25 i'll be going 5 stud.
Here's the pics 17x7's on the LHS and 15x6.5 on the RHS;
Edited by D_Stirls
ruby, malpassi's are know for making the squeeling noise on startup. sometimes from new. havnt had any fail on me, but i wouldnt doubt they do. personally i like aeromotive. has yours got a black or silver top? black is 1.7:1, silver is 1:1
I think my car is the anti christ! Just finished new pads and rotors, gearbox oil, diff oil, engine oil and filter change and a good wash down under the bonnet. Take it for a spin last night to bed the rotors and pads in, and discover i now have another coolant leak! Seems to be coming from around the water pump, that was only put on 10k ago! Hoping its just a loose bolt and not a shagged pump!
yeah i know what thats like
i got a new isc52mm radiator, n1 water pump, racing hose and nismo coolant put in earlier this yr
next day i lose 20% of my coolant via a cracked hose in the heater core (back of the engine, real pain in the arse to get to)
ahh well
two steps forward, one back - always the way with the older cars
-D
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
