ffs half of you whinge there are too many stickies, now you are whinging when I get rid of some .... no pleasing some people
Can't keep everyone happy all the time :thumbsup:
i like accents what can i say.
sometimes you just dont have protection on u. what am i suppose to say in the heat of the moment. ich bin nein fook
in other news look at this mofo taking speed holes to a whole new level
Edited by Inline 6
Hey guys been a while since I jumped on here last.
I didn't want to start a whole new topic for this but does anyone have any comments, criticism or praise about SuperSpark coilpacks?
You can send me a PM if we aren't into publicly flaming brand names here.
Cheers :woot:
How come yours has them in the front bar Dan?
Got some new parts going on the GT-R within the next few weeks :woot:
Look scandy, they come pre wound right down aha.
And the clutch is off a member off her with a custom pressure plate amd the clutch plate its self is heaps nice and meaty its done sweet f**k all K'z as with the coilovers, the old owner still had the wrapping and boxing etc when he got them from Tein.
Should be good can't wait, as for any other plans I think I'll be leaving the car as it is and any other tiny imperfections will be ironed out ;) Can't wait till them 'overs are in lol
Edited by Weezy
Cheers :woot:
no idea about superspark but a mate of mine is running yellowjackets and he has 250kw and they dont short out or cause misfire ;)
hey Mitch, it's amazing how good those water jackets look.
Back in the day, peeps would bring Nissan (Datsun then) heads into work and 95% of them would be riddled with cancer (corrosion) around every water entry.
cause im gangsta weezy :woot:
question i hear many a time, come with the car they dont really bother me and allows me to relax in those odd times i see another blue 32 driving around because i know its not mine from the front ;)
i guess the idea was lil more airflow to the radiator
Edited by Inline 6
yeah i know hey Pete.
my mates corolla engine had corrosion almost the the cylinder :|
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
