hey all, just putting the word out, a mate of mine is looking to swap his BA xr6 turbo + cash his way for a decent 32/s13/200
it has:
*fmic
*3" zorst
*flashtune
*with flash tuner
*monza custom air box
*pod
*tiptronic
*makes about 260rwkw
if u want moar info pm me :(
haha r32 w/rb25det..
yes yes i have bought a toyota.. just got a nissan engine :P
Check the voltage of your battery whilst car is on (alternator charging) If it's below 14v or so, then you've got a problem.
Dale's brother.
No he can do the slotting but he can't do the machining as both sides have to be done in the same setup and with a CNC you can only work on one side per setup.
Luke from memory the machining was around $25+GST each last time i got mine done.
i still dont have any pics, lol, but im heading out for grip in the 34 soon, only bought the 31 coz i was selling the 34, but now im keeping it, the 31 will probably be up for grabs after i fix its little demon (something draining the battery)
1989 R31 Series 3 silhouette, painted S15 pewter
was told it has around 45000k's on the RB20DET, but i dunno how reliable that info is. Is registered (been through regency) with the RB20. brakes would have been upgraded for the engine swap, but the previous owner couldn't tell me what exactly they were upgraded to.
RB20 gearbox
heavy duty clutch
Cusco strut brace
battery relocated to boot
FMIC with custom hard piping, some sort of BOV attached, all plumbed into the system tho, mad flutters.
dual core radiator
vented catch can
Jaycar boost controller
Remapped R32 Ecu
aftermarket guages, oil pressure, volts, boost, water temp and tacho.
the usual audio upgrades
i think thats pretty much it.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
