Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
ur diagnostic skills are fail... =P
if i was a betting, wow, i'd probably put my car up on it not being the video card =D
could be soo many other things making it do that... number 1 is the power supply! i'll also throw my hat in the ring and offer u some free help, just lmk
ps. hoodie thread up soonish
Luke, i just worked out what it is... =D
but i'm not going to tell you what it is because if you try to fix it and mess up you could end up killing stuff!
however i will say this, whoever you take it to will set it up and it'll probably turn on first time, straight away and u'll both be like "hu?" =P
^ what a graph card that's not seated correctly in it's slot?
wow, i should actually start taking bets with people on this! =P
no, as i said before, nothing to do with vidoe card... unlikley that one would just randomly pop out!! =\
Tell tell..... I'll give good prices on jap stuff lol
just drop round and i'll fix, fix!
edit: and coz u get me good prices i wont slug you the $40 i would to a customer for fixing it =P
Edited by Fishpaste~
With big turbos cams can make you up to 50kw depending on the size of the turbo and the amount of head work done as they allow you to move the turbos into their efficiency range, but like chad said with small turbos they won't affect peak power much but will allow you to move the power around the rev range and can get you some nice gains on torque.
Here's some graphs from when we were playing with the cam gears on my car.
cheers man, might go ahead with these os cams
see what willal can do with them once i get a new exhaust fitted
Hey guys, I was wondering if any of you have heard of GT Autosound in Glynde, and if they are a reputable workshop. Thanks in advance.
yeah their pretty good their man and reasonble prices with what you get out of it
Sweet. How long u reckon it would take? Have to head down to Marino around 9am so could pop by after that?
Cheers.
prob 15 mins all up... thing is i'll be at uni from 9 till 4 tomorrow, then have district basketball
so either drop round tonight or tuesday!
u gonna be up for abit still? If u are I'll pop around soon.
George and Theo are excellent guys. Havn't had any work done by them, but never heard a bad word about their work :ph34r:
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
