dale, where did u get your catch can made?
want a setup similar to yours.. with the breather etc..
cheers
It's just a Greddy copy can that i got off eBay for $45. i added the filter though, i just drilled and tapped a hole then used a -8 barbed fitting and a filter that i got from Autobahn for $8. If you do the same though make sure you use a -10 size fitting as the filter is to small on mine and when i put the car back together i'll be making it bigger.
I have to make up the brackets to hold the can as well.
cheers
yo, head down to see niko at smooth.
he made me a perfect catch can for my ca in the drift car.
big and user friendly and didnt cost much at all and they fitted it up with new lines since my old one was too small.
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :) )
Fave photo
Very nice - I've seen a few people use that one - where is it at?
I'm having injector issues AGAIN. 3 weeks after replacing 2, another 2 (not replaced) have started leaking. pissed off
and i called main north nissan. OEM nissan 444cc injector = $437 EACH!!!!1one... and then I find a place in japan that can post me a set of Nismo 600cc's for $990. Geee, whatever shall I do? :happy:
Just sucks - have to drive the car as little as possible in the meantime. *grumble* already the car is going in this weekend to get the spoilers and bumpers painted, couple dents removed, the rear bumper reo fixed from last sundays rear-end accident, calipers and hubs powdercoated and the oil relocation kit relocated (its in a really daft place atm, very low to the ground - good for capacity but not great when you go to park and have a concrete bollard hit the oil filter...)
-D
-D
Get a set of 570, 660 or 750's off these guy for $780. And they're in Australia.
http://www.injectorsonline.com/indivprod.p...=74&scid=12
Edited by D_Stirls
just go for a 3071R Matty, very similar compressor but already fitted with the T3 rear.
3071R wont have the responsiveness i want though (its going on a basically stock internaled RB20). I mean, we could make the new mani with a T25 flange, but that stuffs me for future upgrades
*edit*
Abe, 3076R is worse for me lol
Edited by Matty 31
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
