oooo... fabrication of sump extension almost complete, short block almost complete!!! =D
just need to sell my PFC, anyone?
How much haha? Swap ECU's + cash your way maybe if the price is right although I'm not really fussed if I keep the standard ECU, plan on keeping mine as is really and just maintain its cleanliness
Awesome video for all you GT-R lovers;
Z9 Filter if it's a 225, 245 or 265 6 cylinder, which is actually the same thread as RB's use but a lot bigger.
Our old dirt circuit Open Wheeler was running a Jeff Juring built 265 HEMI making around the 350HP mark.
Ahh, have always had a soft spot for those Hemis....do you recall what was done to it Dale?
We had a cam grinder and used to put our own profiles on the cam lobes with various masters to choose from in the cupboard, then get get them nitrided.
Messed around with the hydraulic lifters in those things and turned them into solids just so we could get ridiculous lifts, durations & overlaps that'd shake the whole car on idle...strictly for drags though.
Go swimming in the 4wd did we Matt haha
seems one of my last escapades where i had the bottom of the doors below water level by at least an inch and a bit was the icing on the cake. splashed water up inside my door, got into my high/low pass filters (that were mounted in the stock speaker location high in the door). Was alright until i re-fitted the tweeter that had fallen off, which killed the filters i reckon
managed to kill both tweeters as well (were reading 1ohm)
Congratulations to Craig for the arrival on the new one mate
so whos interested in paintball? I wanna organise one closer to christmas or just after, when the weather gets a bit more predictable.
Definitely interested
:D This is gonna sound pretty gay. But for some reason Damo, You were in a dream of mine last night. And you drove a VT commodore.
Yep your right it does sound gay
Yeah, i only tuned it to 10.5psi to increase the life of the turbo. 12psi is at peak efficiency for a stock rb25 turbo.
I have been running on 12 psi for almost about a year now Damo and the turbo was still going strong making 214 odd so rwkw.....for 10psi i think that figure is quite low mate.....as i remember making 180rwkw on 7psi....hopefully whatever it is you can get it sorted out mate
there are times (not many) when the north scares and confuses me.
example, on my way home from a 31 club meet, just drove past elizabeth, about 30 seconds away from my intersection, and im sitting behind a vz commodore, both of us sitting just over the limit, and the rear passenger of the commodore decided walking might be a better way to get home and throw himself out of the car.
onto the asphalt.
at 90k's an hour.
without a shirt on.
so both me and the commo throw on the skids and stop, i jump out and run back to the guy, the 2 other blokes in the commo do the same, we get to the guy, hes got blood all over his face, his back and arms are all cut up, and yeah, blood everywhere. and the 2 blokes just throw him back into the car, thank me for stopping, and drive off in a casual way as if all is fine and f**king dandy. f**k.
Just like any other night out for these guys :)
At least the bloke was considerate enough to leave the booze and ciggies in the car before bailing! :)
I lived in Lidabeff during high school ... feral as! :P
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
