Sitting on a train is a kiwi guy, an Aussie bloke, an old lady and a hot blonde with big boobs.The Train goes through a dark tunnel and after a few seconds there is a loud slap.When the train emerges the Kiwi has a large red welt on his face. No one speaks!!! The old lady thinks the Kiwi guy must have groped the blonde and she's slapped him. The blonde thinks the Kiwi guy must have groped the old lady by mistake and he'd been slapped. The Aussie thinks i cant wait till the next tunnel to slap that Kiwi prick again...
once again. its lizbeff.
dont make me stab you.
I grew up in Lidabeff from 1983 onwards until a few years after I finished high school. We called it Lidabeff then. So unless you were there before me and my homies, its "Lidabeff" :huh: ... and its still a shit hole. And I still have family that live there to this day :D
lol at 1983 ur only a newbie so u and ya stuck up homies can piss orff any times ya likes lol
moved to elizabeth in 1964 was glad to get out of the south side of town still live in the north side just a bit further out nowdays and a proud northie :-) .
like they say if ya cant stand the heat get out of the kitchen biatch lol
Edited by mid life crisis
Gee, you're showing your age now ;)
Yeah I remember the skating rink before they closed it. Even the time before the Aquadome. Gosh, I remember when the Elizabeth shops were all open air barely sheltered walkways, before they enclosed it all and expanded it. The Timezone video arcade for lock in sessions where kids went for fights, and played video games in between :thumbsup: Walking the streets at night, and running everytime you heard a car skid to a halt. Was absolutely feral. Guys jumping out of cars with bats and shit and chasing you down for a rough-up! Bored northies liked to drive to find other groups of kids and beat up on them. I went to Lidabeff high school. The roughest school at the time. Fights were commonplace back in those days ... day and night! :down:
Was so glad when I left that neighbourhood and moved south. Got into study and work and never looked back!
yeah im old so what ?
the skating ring and the pool was always a place of fun . we used to ride our pushbikes around the shopping centre and play pool in the upstairs pool room .
never had people chasing me with bats and havent been in a fight since primary school bahhh the elizabeth high was for soft cocks . maybe trouble attracted trouble ?
elizabeth west high was the place too be lol .
just watched the first ep of flashforward, has a fair bit of potential.
Yep, not too bad at all. Dunno if you noticed the Oceanic Airlines billboard placed in the episode, made me laugh (you'll only understand that if you watch Lost)
Love this comment
"On average, 27 per cent of all fatalities in SA each year are aged between 16 and 24," Mr O'Brien said. "There are more than 76,000 P-platers on our roads and these new drivers, particularly those aged between 16 and 20, are up to three times more likely to be involved in a serious road crash."
Ever looked into where the other f**king 73% comes from?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
