well i scared the shit out of myself tonight at work , stacking some shelves and BAM chest pain , couldn't breathe and ended up having an asthma attack :P
luckily a customer had a puffer other wise i would of potentially died :|
fkin scary shit...
Fk that's not good. A mate of mine had a similar thing a couple of weeks ago but he doesn't suffer from asthma. Doc said it was a anxiety attack brought on by stress!
im not even 100% sure what it was , i havent felt like myself the past couple of days and then i was upset, then i couldnt breathe :P
going to the doctors tomorrow first thing to get checked out
Sounds like a heart issue imho. Stacking shelves esp points towards that (asthma attacks dont usually just *hit* - i've had anxiety attacks before, and asthma for the last 30 years, there is most definately a difference)... good idea to get it checked out at the gp
also bear in mind tho, 'energy' drinks, caffeine, painkillers and other factors can cause the same symptoms so dont stress too much lol ... bad choice of words eh
-D
no shit, hes got more rims than all the black people in america
-D
haha, not anymore
these are basically my only set
the old set of chrome ones are for sale (very soon to be sold), black ones have already been snapped up (dosh paid for half these haha)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
