Just got back from a run guys,
Great weather for it car loved it. I need skinnier tyres or rolled guards now that it sits a bit lower,
I think I'll go with skinnier tyres and try that out as I dont want to roll and molester my guards ahaha.
200's pretty much done. just gotta refit the front bar and the cold side cooler pipe and fit the fuel pump. oil cooler was pretty lol, ended up using 4 fittings just on the return line so the hose could clear the rad support and the fmic.
spoiler looks pretty rad. as does my new 'silvia' badge on the boot.
so luke/wayne, hills runs will be in order soon. might bring back the midweek runs.
would post pics. but 3mb photos + capped internet speed = 5 day uploads.
Edited by scandyflick
joisus. GTR pumps are fair beastly compared to the 200's stocker...
and now im off to collect a free carton of beer from work. ;)
Should had gave me a msg on Facebook! I would had come out!
check this thing out and their whole website. Want a 34R NUR with 18km on it?
http://www.zeleperformance.com/vehicle/r34...registered.html
Some very nice cars there ;)
http://www.zeleperformance.com/vehicle/r34...lack-pearl.html
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
