check this thing out and their whole website. Want a 34R NUR with 18km on it?
http://www.zeleperformance.com/vehicle/r34...registered.html
I was at Zele in yokohama 2 weeks ago and had a look at it in the flesh!! ..... heres a few snaps.... 34s everywhere!
Should had gave me a msg on Facebook! I would had come out!
I hardly ever use facebook man, otherwise I would have haha.
Another time,
Dave bring on the mid week runs ftw I had a ball last night it was great.
Jarrad - some advice if you are looking for a R32 GTR. These cars are all pretty old now and if I were you I'd be looking for the following items (unless you want a standard one).
1. Sorted the oil pickup problem. I would look for a larger oil pump & a larger sump &/or baffle kit.
2. A R33 GTR long nose crank (or with a collar).
3. New turbos with steel wheels.
4. A rebuilt engine with forged internals - mainly pistons, piston rings & conrod bolts. The standard conrods are fine for up to 400rwkW.
BTW if you want 18x10" rims then you also need to consider what size & look of tyres you want. 275/35/18 will need the guards to be rolled. 255/35/18 will give you a stretched look. I personally wouldn't get anything wider than 9.5" (I have 18x10 +20 BBS LM rims on mine) as 10" rims also prevent you going to full lock when turning.
I say all this coming from experience (i have owned 2x R32 GTRs since March 2004) and the experience of many (but not all) others. It may cost you more $ to get a car with these mods but I promise this will be less than the dollars, time & heartache when one of the engine or turbos blow.
balls. id love to come for a run, but with the new pump in im not gonna be "driving" it until i get it dyno'd to check the afr's...
... and ive got a going away party that i "have" to make an appearance at...
... on the plus side, ive sold my spare wing... and the front end of the 200 is back together. :thumbsup:
lol, pretty well. its come a fair way from the stocker it was when i bought it...
... now i just need a pfc or something and a z32... hmmm...
Edited by scandyflick
hahahaah yeah i need a sump baffle :thumbsup: but if not sitting at high rpm all the time not too much of a drama
who wants to go for a cruise tonight?? ive got today/ tomorrow off.
I may be keen later on tonight if your still keen Jenkies?
HMMZ i might have to give it a miss actually guys, been playing pretty sht b ball lately so i better get my ass to training. would say can cruise after training but its pretty dodgy car park there and ill stink up the gtr :)
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
