balls. internet is running so f**king slowly. but ive got 8gb left til i hit my cap apparently.
cleared history, cleared cookies, reset router, still running slow as all shit. any ideas?
Sync speed & snr?
Grab a test file to see what sort of speeds you're downloading at, if your ISP doesn't have any grab one of internodes http://mirror.internode.on.net/pub/test/10meg.test
hmm - wilall told me they wernt interested in tuning the stag
Thats funny. I was told some weeks ago to bring mine in for a tune because they have their new 4WD dyno. ;)
i wasnt asking wilall for a tune, was asking their opinion on a problem...?
Sync speed & snr?
snr?
downloading test file at the mo.. 6kb/s. fail.
Modulation on router on the correct setting?
can i get that in computer stupid? (aka, english)
Edited by scandyflick
You can access that setting in the routers home page... usually found at 192.168.1.1
If your on adsl2+ usually the modem/router likes that setting better than mmode or gdmt. Might not be the issue either.
Incidentally I'm surprised moderators haven't stumbled across the threads in the ' General Automotive Discussion' section of the forum..... LOL!
yep, thats pretty bad.
You can find yor sync speed in the modems config pages too, normally under something like statistics/line settings
If you're syncd well above 6kbps then it's time to call your isp to see wtf is going on, could be backhaul issues or incorrectly shaped, if the sync speed matches the download speed then it's also time to call your isp and lodge a line fault.
Which ISP btw
adelaide blows. had a friends going away party tonight. got refused from 2 venues ive never been to before because my footwear 'wasnt up to standard'.
are you f**king kidding? how the f**k can a glorified pub have a goddamn dress code? sorta killed what was shaping up to be a decent evening.
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. ;)
Coz he's a batty boy amiright?
Anyways,
Going to look at this white GTR monday with Weazy (if he can make it). If that doesn't all go to plan Jenkies is going to be without a GTR.
At 6k a second he'd be using ANSI modulation - which is unsupported by most ISP's.
G.DMT is the standard modulation type for most, ADSL2 and 2+ have their own modulation extensions, such as Annex M and the like.
For what its worth, I'd turn the router off for 30 minutes and then turn it back on - sometimes that will cause the exchange to do a full retrain on the adsl synch when it comes back online...
And the router can generally be found by opening up a command prompt and typing ipconfig /all - whichever is your default gateway is usually the modem router (unless you have a windows or linux gateway)
-D
all this computer talk is nuking my brain...
LOL Dave, refusal had nothing to do with your shoes........just a standard line, otherwise you'd scream discrimination if they gave you the real reason. :cool:
haha, probably. sounded a bit sus to me. f**kin ruined my night though.
Fashion Police are at it again.
What shoes did they refuse?
What's he gonna do if he gets bashed in the streets
He ain't a bouncer he's just the fasion police
good song haha
funkoars f/ hilltop hoods - What I Want
welp, found out why my internet sucks.
its cause adam sucks.
they apparently cap uploads aswell. balls.
think ill move back to internode.
shits gonna be frustrating for the next 12 days.
yeah , they count your uploads.
Adam are shit, they overload their rim's causing shit speeds and reliability.
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
