Nice R Jarred but you do realise that when you own an import you are forbidden to park any closer than 30cm to the curb so you never risk scratching your rims.
I will forgive this 1st offence but please be mindful of your proximity next time you park your car.
Thanks dude. But seeing as I've come from a 32 with the rims extremely hanging out of the guards I'm pretty careful when approaching gutters.
Mod list to check off in the next 6 months.
Kakimoto Regu 06
Tein super street coilovers
18x10+12 TE37
New air intake (can't even hear my BOV :laugh: )
Got the car back after getting the hubs painted and the calipers powder coated... also had my spoiler mounted again and took the front spoiler lip to get prepped for the riverland show... some pix
Few more touch ups required on the boot, the bonnet and the drivers door and a couple tiny dents on the passenger side. Not much more to go..
-D
because there abbo's and the legal system in australia is too scared of not being politically correct so f**ks like then get back on the street for the simple fact they are abbo.
all those scumbags have a criminal record longer sled's ban list, yet they still get all there benefit payments and go rob places such as vilis
edit: domar car looks clean as f**k, but plzzzzzz put a gtr lip on there :laugh:
Edited by rhys5169
hahah @ sleds ban list
yeah I did mention in the post that its getting spray painted atm ;P
-D
Well I just got defected. Done for cage, suspension, steering wheel. First defect on the car ever. Off to regency I go :laugh:
I feel your pain i got done last month they said my steering wheel was to small aswell but its withing the requirements...
So you are actually going to have the front lip on it? Thought you took it off because its only for "track cars"
no i took it off because i kept scraping driveways and speed humps and the like and i was damaging the shit out of it
as it is I had to get it bogged and sanded in many places
its going on for the riverland show, and then it'll come straight off until I can get some replacement suspension that increases my ride height by at least a cm if not 2
-D
Your ride height is far from low
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
